Dell Inspiron 17R-N7010 Keyboard Replacement
  1. Dell Inspiron 17R-N7010 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Flip over the laptop so the back is facing upwards.
    • Locate the battery compartment.
    • Make sure your laptop is turned off before disassembly.
    Ask FixBot
  2. Dell Inspiron 17R-N7010 Keyboard Replacement: step 2, image 1 of 1
    • Slide both locks away from the center of the battery.
    • After you hear a click, pull out the battery.
    Ask FixBot
  3. Dell Inspiron 17R-N7010 Keyboard Replacement, Keyboard: step 3, image 1 of 1
    • Remove both screws that connect the keyboard to the laptop chassis.
    Ask FixBot
  4. Dell Inspiron 17R-N7010 Keyboard Replacement: step 4, image 1 of 1
    • Look for the four locks that secure the keyboard on top.
    • Push the lock into the case with a plastic opening tool. It is important to note that each lock has a spring behind it
    • Lift the keyboard up a little bit. A plastic opening tool or nylon spudger can help in lifting the keyboard.
    Ask FixBot
  5. Dell Inspiron 17R-N7010 Keyboard Replacement: step 5, image 1 of 1
    • Lift the top side of the keyboard up and place it upside down. This enables you to access the keyboard cable, which is connected to the motherboard.
    • Lift up the left side of the brown tab with your fingernail and it will open up at 90-degree angle. This will unlock the connector.
    • Unplug the keyboard connector from the motherboard.
    • Remove the keyboard.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 43
All Time: 1,773
