Dell Inspiron 17R-N7010 Fan Replacement
    1. Dell Inspiron 17R-N7010 Fan Replacement, Battery: step 1, image 1 of 1
      • Flip over the laptop so the back is facing upwards.
      • Locate the battery compartment.
      • Make sure your laptop is turned off before disassembly.
      Ask FixBot
    2. Dell Inspiron 17R-N7010 Fan Replacement: step 2, image 1 of 1
      • Slide both locks away from the center of the battery.
      • After you hear a click, pull out the battery.
      Ask FixBot
    1. Dell Inspiron 17R-N7010 Fan Replacement, Palm Rest: step 3, image 1 of 3 Dell Inspiron 17R-N7010 Fan Replacement, Palm Rest: step 3, image 2 of 3 Dell Inspiron 17R-N7010 Fan Replacement, Palm Rest: step 3, image 3 of 3
      • Remove the four screws from the back panel.
      • Flip the laptop over and open it to view the keyboard.
      • Disconnect the keyboard from the laptop by lifting up the latch holding the ribbon cable in place.
      Ask FixBot
    2. Dell Inspiron 17R-N7010 Fan Replacement: step 4, image 1 of 3 Dell Inspiron 17R-N7010 Fan Replacement: step 4, image 2 of 3 Dell Inspiron 17R-N7010 Fan Replacement: step 4, image 3 of 3
      • Close the laptop and flip it over so the bottom is facing upwards.
      • Remove the two screws from the small panel.
      • Remove the small back panel.
      • Slide the CD drive out of the laptop.
      • Remove the three screws from the CD drive slot.
      Ask FixBot
    3. Dell Inspiron 17R-N7010 Fan Replacement: step 5, image 1 of 1
      • This step is tricky and can feel like you are breaking the laptop. Follow the next steps with caution to avoid damaging the laptop.
      • Remove the top cover by inserting a spudger under the surface.
      • Working clockwise, pry upwards with the spudger to detach the clips.
      Ask FixBot
    4. Dell Inspiron 17R-N7010 Fan Replacement: step 6, image 1 of 2 Dell Inspiron 17R-N7010 Fan Replacement: step 6, image 2 of 2
      • Disconnect the ribbon cables.
      • Remove the cover to access the inner hardware of the laptop.
      Ask FixBot
    1. Dell Inspiron 17R-N7010 Fan Replacement, Fan: step 7, image 1 of 3 Dell Inspiron 17R-N7010 Fan Replacement, Fan: step 7, image 2 of 3 Dell Inspiron 17R-N7010 Fan Replacement, Fan: step 7, image 3 of 3
      • Locate the fan at the top left corner.
      • Remove the fan by disconnecting the coupled wires from the white port.
      • Disconnect the wire strip by lifting up the latch holding the wire in place.
      • Unscrew the remaining two screws.
      • Remove the fan.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 1,572
