Dell Inspiron 1750 Screen Replacement
    1. Dell Inspiron 1750 Screen Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 1750 Screen Replacement, Battery: step 1, image 2 of 2
      • Unplug the laptop before changing the battery to avoid electric shock.
      • Place the laptop on a flat stable surface.
      • Flip the laptop over so the underside is visible.
      Ask FixBot
    2. Dell Inspiron 1750 Screen Replacement: step 2, image 1 of 2 Dell Inspiron 1750 Screen Replacement: step 2, image 2 of 2
      • Locate the battery lock switch.
      • Slide the lock switch to the left (away from the lock symbol).
      • Slide the battery out away from the laptop.
      Ask FixBot
    1. Dell Inspiron 1750 Screen Replacement, Dell Inspiron 1750 Teardown: step 3, image 1 of 1
      • Separate the screws by size and head type. Be sure to keep them in a safe place.
      • Remove the sixteen 2mm Phillips #00 screws from the bottom of the laptop.
      • Remove the two 2mm Phillips #0 screws from the hard drive port.
      Ask FixBot
    2. Dell Inspiron 1750 Screen Replacement: step 4, image 1 of 3 Dell Inspiron 1750 Screen Replacement: step 4, image 2 of 3 Dell Inspiron 1750 Screen Replacement: step 4, image 3 of 3
      • Keep your hand pressed firmly on the back panel to prevent it from falling.
      • Flip the laptop over horizontally and open up the lid.
      • Insert the tip of the plastic opening tool into the upper left corner of the panel.
      • Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose. Next gently remove the panel.
      • Remove the four 2mm Phillips #0 screws at the top of the keyboard.
      • Slide the plastic opening tool around the keyboard until the keyboard is completely loose. Gently remove the keyboard.
      Ask FixBot
    3. Dell Inspiron 1750 Screen Replacement: step 5, image 1 of 3 Dell Inspiron 1750 Screen Replacement: step 5, image 2 of 3 Dell Inspiron 1750 Screen Replacement: step 5, image 3 of 3
      • Do not lift the keyboard completely free to avoid damaging its connections to the laptop interior.
      • Locate the small black latch attached to blue tape.
      • Lift the small latch with your finger and pull the blue tape from its port.
      • Slide the keyboard away from the mousepad and set it aside.
      Ask FixBot
    4. Dell Inspiron 1750 Screen Replacement: step 6, image 1 of 3 Dell Inspiron 1750 Screen Replacement: step 6, image 2 of 3 Dell Inspiron 1750 Screen Replacement: step 6, image 3 of 3
      • Always pull wires from their plastic ends, not their cables, to avoid wire damage.
      • Locate the three wires in the top left corner of the metal panel.
      • Use the spudger to push the two cables out of their ports.
      • Pull the blue tab directly up to remove middle wire.
      Ask FixBot
    5. Dell Inspiron 1750 Screen Replacement: step 7, image 1 of 2 Dell Inspiron 1750 Screen Replacement: step 7, image 2 of 2
      • Remove the three 1mm Phillips #00 screws on the metal plate.
      • Lift the black cover and slide the blue tab away from the cover.
      Ask FixBot
    6. Dell Inspiron 1750 Screen Replacement: step 8, image 1 of 3 Dell Inspiron 1750 Screen Replacement: step 8, image 2 of 3 Dell Inspiron 1750 Screen Replacement: step 8, image 3 of 3
      • Gently remove the three grey wires from the metal tabs.
      • Insert the tip of the plastic opening tool into the bottom left corner of the panel.
      • Gently lift off the top metal panel.
      Ask FixBot
    1. Dell Inspiron 1750 Screen Replacement, Screen: step 9, image 1 of 3 Dell Inspiron 1750 Screen Replacement, Screen: step 9, image 2 of 3 Dell Inspiron 1750 Screen Replacement, Screen: step 9, image 3 of 3
      • Use the spudger to lift the wires from their connections.
      • Remember to pull wires from their plastic ends, not their cables, to avoid wire damage.
      • Flip the laptop over and pull the connections through until they are free from the laptop interior.
      Ask FixBot
    2. Dell Inspiron 1750 Screen Replacement: step 10, image 1 of 2 Dell Inspiron 1750 Screen Replacement: step 10, image 2 of 2
      • Remove the two 2mm Phillips #0 screws from the screen hinges.
      • Lift the screen away from the laptop and gently set it down.
      • Put the rest of the laptop aside.
      Ask FixBot
    3. Dell Inspiron 1750 Screen Replacement: step 11, image 1 of 3 Dell Inspiron 1750 Screen Replacement: step 11, image 2 of 3 Dell Inspiron 1750 Screen Replacement: step 11, image 3 of 3
      • Use the plastic opening tool to remove the plastic cover from the screen.
      • Remove the eight 2mm Phillips #0 screws from the corners of the screen.
      • Lift the screen away from the back panel.
      Ask FixBot
    4. Dell Inspiron 1750 Screen Replacement: step 12, image 1 of 2 Dell Inspiron 1750 Screen Replacement: step 12, image 2 of 2
      • Remove the four 2mm Phillips #0 screws from the sides of the screen.
      • Remove the side railings from both sides of the screen by pulling the railings gently away from the screen.
      Ask FixBot
3 other people completed this guide.
Tina Rickard
771 Reputation
5 Guides authored
Cal Poly, Team 6-3, Forte Spring 2014 Member of Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 Members
84 Guides authored
2 Guide Comments
Succeed ! Thanks.
Note: @ First opening, I add to do step 9 before the step 8. The antenna wire prevent you to "Gently lift off the top metal panel".
wxadha - Reply Share
My screen almost always has a pink spotty look. How do I know if I need to replace the screen, or just the wires?
Kathleen - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 112
All Time: 4,286
