Dell Inspiron 1750 Optical Drive Replacement
    1. Dell Inspiron 1750 Optical Drive Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 1750 Optical Drive Replacement, Battery: step 1, image 2 of 2
      • Unplug the laptop before changing the battery to avoid electric shock.
      • Place the laptop on a flat stable surface.
      • Flip the laptop over so the underside is visible.
      Ask FixBot
    2. Dell Inspiron 1750 Optical Drive Replacement: step 2, image 1 of 2 Dell Inspiron 1750 Optical Drive Replacement: step 2, image 2 of 2
      • Locate the battery lock switch.
      • Slide the lock switch to the left (away from the lock symbol).
      • Slide the battery out away from the laptop.
      Ask FixBot
    1. Dell Inspiron 1750 Optical Drive Replacement, Optical Drive: step 3, image 1 of 2 Dell Inspiron 1750 Optical Drive Replacement, Optical Drive: step 3, image 2 of 2
      • Remove the 2mm Phillips #00 screw next to the module cover.
      • Pull the disc drive away from the laptop.
      Ask FixBot
4 other people completed this guide.
Tina Rickard
771 Reputation
5 Guides authored
Cal Poly, Team 6-3, Forte Spring 2014 Member of Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 108
All Time: 1,423
