Dell Inspiron 1750 Hard Drive Replacement
Views: 10K
View statistics:
Past 24 Hours:
Past 7 Days:
27
Past 30 Days:
120
All Time:
10,465
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
You may want to remove the hard drive to upgrade to a higher capacity drive or if your files have become corrupted and unrecoverable.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
    1. Dell Inspiron 1750 Hard Drive Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 1750 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Unplug the laptop before changing the battery to avoid electric shock.
      • Place the laptop on a flat stable surface.
      • Flip the laptop over so the underside is visible.
      Ask FixBot
    2. Dell Inspiron 1750 Hard Drive Replacement: step 2, image 1 of 2 Dell Inspiron 1750 Hard Drive Replacement: step 2, image 2 of 2
      • Locate the battery lock switch.
      • Slide the lock switch to the left (away from the lock symbol).
      • Slide the battery out away from the laptop.
      Ask FixBot
    1. Dell Inspiron 1750 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Dell Inspiron 1750 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
      • Remove the two 1mm double wide Phillips #00 screws.
      • Pull the hard drive away from the laptop.
      Ask FixBot
    2. Dell Inspiron 1750 Hard Drive Replacement: step 4, image 1 of 2 Dell Inspiron 1750 Hard Drive Replacement: step 4, image 2 of 2
      • Keep all screws in a safe place. You may need to use them for your new hard drive.
      • Remove the two #00 1mm screws on both sides of the hard drive.
      • Pull the hard drive cover away from the hard drive and set the cover aside.
      Ask FixBot
4 other people completed this guide.
Tina Rickard
771 Reputation
5 Guides authored
Cal Poly, Team 6-3, Forte Spring 2014 Member of Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 27
Past 30 Days: 120
All Time: 10,465
