Dell Inspiron 1721 Display Assembly Replacement
    1. Dell Inspiron 1721 Display Assembly Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 1721 Display Assembly Replacement, Battery: step 1, image 2 of 2
      • Slide tabs outward to undo the locks.
      • Grab and pull the battery away from the device to remove.
      Ask FixBot
    1. Dell Inspiron 1721 Display Assembly Replacement, Hinge Plate Cover: step 2, image 1 of 3 Dell Inspiron 1721 Display Assembly Replacement, Hinge Plate Cover: step 2, image 2 of 3 Dell Inspiron 1721 Display Assembly Replacement, Hinge Plate Cover: step 2, image 3 of 3
      • Pry up on the corner of the hinge cover with an iFixit opening tool.
      • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
      • Lean the display back as far as it goes and lift up on the hinge cover to remove.
      Ask FixBot
    1. Dell Inspiron 1721 Display Assembly Replacement, Keyboard: step 3, image 1 of 3 Dell Inspiron 1721 Display Assembly Replacement, Keyboard: step 3, image 2 of 3 Dell Inspiron 1721 Display Assembly Replacement, Keyboard: step 3, image 3 of 3
      • Remove four 3mm Phillips #1 screws from the top of the keyboard.
      • Use an iFixit opening tool to slide the keyboard upwards toward the display.
      • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
      Ask FixBot
    1. Dell Inspiron 1721 Display Assembly Replacement, Display Assembly: step 4, image 1 of 2 Dell Inspiron 1721 Display Assembly Replacement, Display Assembly: step 4, image 2 of 2
      • Loosen the two captive Phillips #0 screws.
      • Remove the cover.
      Ask FixBot
    2. Dell Inspiron 1721 Display Assembly Replacement: step 5, image 1 of 1
      • Disconnect the antenna connectors from the WLAN card.
      Ask FixBot
    3. Dell Inspiron 1721 Display Assembly Replacement: step 6, image 1 of 3 Dell Inspiron 1721 Display Assembly Replacement: step 6, image 2 of 3 Dell Inspiron 1721 Display Assembly Replacement: step 6, image 3 of 3
      • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
      • Disconnect the display connector.
      • Disconnect the second connector, then remove the cable from the base.
      Ask FixBot
    4. Dell Inspiron 1721 Display Assembly Replacement: step 7, image 1 of 3 Dell Inspiron 1721 Display Assembly Replacement: step 7, image 2 of 3 Dell Inspiron 1721 Display Assembly Replacement: step 7, image 3 of 3
      • Remove the display cable from the palm rest.
      • Use a spudger to carefully pull the antenna wires through to front of the device.
      Ask FixBot
    5. Dell Inspiron 1721 Display Assembly Replacement: step 8, image 1 of 2 Dell Inspiron 1721 Display Assembly Replacement: step 8, image 2 of 2
      • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
      • Lift the assembly straight up to separate it from the body of the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 47
All Time: 481
