Dell Inspiron 1721 Back Cover Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
54
All Time:
564
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you are experiencing any problems with the device not reading a disk, overheating, or any other issues with an interior part of the Dell Inspiron 1721 this guide can be a helpful starting place for getting access to remove or replace any components.
Before attempting to take the a back cover off make sure that the device is completely turned off.
Tools
    1. Dell Inspiron 1721 Back Cover Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 1721 Back Cover Replacement, Battery: step 1, image 2 of 2
      • Slide tabs outward to undo the locks.
      • Grab and pull the battery away from the device to remove.
      Ask FixBot
    1. Dell Inspiron 1721 Back Cover Replacement, Hinge Plate Cover: step 2, image 1 of 3 Dell Inspiron 1721 Back Cover Replacement, Hinge Plate Cover: step 2, image 2 of 3 Dell Inspiron 1721 Back Cover Replacement, Hinge Plate Cover: step 2, image 3 of 3
      • Pry up on the corner of the hinge cover with an iFixit opening tool.
      • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
      • Lean the display back as far as it goes and lift up on the hinge cover to remove.
      Ask FixBot
    1. Dell Inspiron 1721 Back Cover Replacement, Display Assembly: step 3, image 1 of 2 Dell Inspiron 1721 Back Cover Replacement, Display Assembly: step 3, image 2 of 2
      • Loosen the two captive Phillips #0 screws.
      • Remove the cover.
      Ask FixBot
    2. Dell Inspiron 1721 Back Cover Replacement: step 4, image 1 of 1
      • Disconnect the antenna connectors from the WLAN card.
      Ask FixBot
    3. Dell Inspiron 1721 Back Cover Replacement: step 5, image 1 of 3 Dell Inspiron 1721 Back Cover Replacement: step 5, image 2 of 3 Dell Inspiron 1721 Back Cover Replacement: step 5, image 3 of 3
      • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
      • Disconnect the display connector.
      • Disconnect the second connector, then remove the cable from the base.
      Ask FixBot
    4. Dell Inspiron 1721 Back Cover Replacement: step 6, image 1 of 3 Dell Inspiron 1721 Back Cover Replacement: step 6, image 2 of 3 Dell Inspiron 1721 Back Cover Replacement: step 6, image 3 of 3
      • Remove the display cable from the palm rest.
      • Use a spudger to carefully pull the antenna wires through to front of the device.
      Ask FixBot
    5. Dell Inspiron 1721 Back Cover Replacement: step 7, image 1 of 2 Dell Inspiron 1721 Back Cover Replacement: step 7, image 2 of 2
      • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
      • Lift the assembly straight up to separate it from the body of the device.
      Ask FixBot
    1. Dell Inspiron 1721 Back Cover Replacement, Back Cover: step 8, image 1 of 1
      • Disconnect the touch pad connector.
      Ask FixBot
    2. Dell Inspiron 1721 Back Cover Replacement: step 9, image 1 of 3 Dell Inspiron 1721 Back Cover Replacement: step 9, image 2 of 3 Dell Inspiron 1721 Back Cover Replacement: step 9, image 3 of 3
      • Lay the device flat and remove the 17 7mm Phillips #0 screws.
      • Use an iFixit opening tool to separate the back cover.
      • Remove the back cover.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 54
All Time: 564
