Dell Inspiron 17-7737 RAM Replacement
    1. Dell Inspiron 17-7737 RAM Replacement, Battery: step 1, image 1 of 1
      • Close the display and turn the computer over.
      • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
      • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
      Ask FixBot
    2. Dell Inspiron 17-7737 RAM Replacement: step 2, image 1 of 3 Dell Inspiron 17-7737 RAM Replacement: step 2, image 2 of 3 Dell Inspiron 17-7737 RAM Replacement: step 2, image 3 of 3
      • Pry out the battery cover from the computer base using an opening tool.
      Ask FixBot
    3. Dell Inspiron 17-7737 RAM Replacement: step 3, image 1 of 1
      • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
      Ask FixBot
    4. Dell Inspiron 17-7737 RAM Replacement: step 4, image 1 of 2 Dell Inspiron 17-7737 RAM Replacement: step 4, image 2 of 2
      • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
      • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
      Ask FixBot
    1. Dell Inspiron 17-7737 RAM Replacement, RAM: step 5, image 1 of 3 Dell Inspiron 17-7737 RAM Replacement, RAM: step 5, image 2 of 3 Dell Inspiron 17-7737 RAM Replacement, RAM: step 5, image 3 of 3
      • Pry the memory module's cover off of the computer's base using an opening tool.
      Ask FixBot
    2. Dell Inspiron 17-7737 RAM Replacement: step 6, image 1 of 2 Dell Inspiron 17-7737 RAM Replacement: step 6, image 2 of 2
      • Remove the 1st stick of memory by pushing the two lock pins to the side and pulling the stick out of the base.
      Ask FixBot
    3. Dell Inspiron 17-7737 RAM Replacement: step 7, image 1 of 2 Dell Inspiron 17-7737 RAM Replacement: step 7, image 2 of 2
      • Remove the second RAM stick in the same fashion.
      Ask FixBot
Mark Batista
457 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 53
All Time: 425
