Dell Inspiron 17-5755 Keyboard Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
84
All Time:
1,193
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will allow you to replace a broken keyboard for the Dell Inspiron 17-5755. Please ensure that the battery is removed before performing this replacement.
Tools
    1. Dell Inspiron 17-5755 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
      Ask FixBot
    2. Dell Inspiron 17-5755 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron 17-5755 Keyboard Replacement: step 2, image 2 of 2
      • Find the battery release latch on the bottom side of the computer.
      • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
      Ask FixBot
    3. Dell Inspiron 17-5755 Keyboard Replacement: step 3, image 1 of 1
      • Safely remove the battery from the laptop.
      Ask FixBot
    1. Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: step 4, image 1 of 2 Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: step 4, image 2 of 2
      • Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
      Ask FixBot
    2. Dell Inspiron 17-5755 Keyboard Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
      Ask FixBot
    3. Dell Inspiron 17-5755 Keyboard Replacement: step 6, image 1 of 2 Dell Inspiron 17-5755 Keyboard Replacement: step 6, image 2 of 2
      • Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
      Ask FixBot
    4. Dell Inspiron 17-5755 Keyboard Replacement: step 7, image 1 of 3 Dell Inspiron 17-5755 Keyboard Replacement: step 7, image 2 of 3 Dell Inspiron 17-5755 Keyboard Replacement: step 7, image 3 of 3
      • Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
      • Afterwards, carefully detach the backlight cable from the laptop.
      Ask FixBot
    5. Dell Inspiron 17-5755 Keyboard Replacement: step 8, image 1 of 3 Dell Inspiron 17-5755 Keyboard Replacement: step 8, image 2 of 3 Dell Inspiron 17-5755 Keyboard Replacement: step 8, image 3 of 3
      • Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
      • Afterwards, carefully slide the cable out of its slot.
      Ask FixBot
    6. Dell Inspiron 17-5755 Keyboard Replacement: step 9, image 1 of 2 Dell Inspiron 17-5755 Keyboard Replacement: step 9, image 2 of 2
      • Now that the keyboard is detached from the laptop, you may safely remove it.
      Ask FixBot
3 other people completed this guide.
Gabriel Espinal
248 Reputation
1 Guide authored
USF Tampa, Team S6-G1, Lacy Spring 2017 Member of USF Tampa, Team S6-G1, Lacy Spring 2017
USFT-LACY-S17S6G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 84
All Time: 1,193
