Dell Inspiron 17-5755 Display Panel Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
29
Past 30 Days:
92
All Time:
1,655
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will allow you to replace a broken display panel for the Dell Inspiron 17-5755. Please ensure that the battery is removed before performing this replacement.
Tools
    1. Dell Inspiron 17-5755 Display Panel Replacement, Battery: step 1, image 1 of 1
      • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
      Ask FixBot
    2. Dell Inspiron 17-5755 Display Panel Replacement: step 2, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 2, image 2 of 2
      • Find the battery release latch on the bottom side of the computer.
      • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
      Ask FixBot
    3. Dell Inspiron 17-5755 Display Panel Replacement: step 3, image 1 of 1
      • Safely remove the battery from the laptop.
      Ask FixBot
    1. Dell Inspiron 17-5755 Display Panel Replacement, Keyboard: step 4, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement, Keyboard: step 4, image 2 of 2
      • Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
      Ask FixBot
    2. Dell Inspiron 17-5755 Display Panel Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
      Ask FixBot
    3. Dell Inspiron 17-5755 Display Panel Replacement: step 6, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 6, image 2 of 2
      • Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
      Ask FixBot
    4. Dell Inspiron 17-5755 Display Panel Replacement: step 7, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 7, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 7, image 3 of 3
      • Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
      • Afterwards, carefully detach the backlight cable from the laptop.
      Ask FixBot
    5. Dell Inspiron 17-5755 Display Panel Replacement: step 8, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 8, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 8, image 3 of 3
      • Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
      • Afterwards, carefully slide the cable out of its slot.
      Ask FixBot
    6. Dell Inspiron 17-5755 Display Panel Replacement: step 9, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 9, image 2 of 2
      • Now that the keyboard is detached from the laptop, you may safely remove it.
      Ask FixBot
    1. Dell Inspiron 17-5755 Display Panel Replacement, Motherboard: step 10, image 1 of 1
      • Use a Phillips #0 screwdriver to unscrew the two 8mm screws which secure the base cover.
      Ask FixBot
    2. Dell Inspiron 17-5755 Display Panel Replacement: step 11, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 11, image 2 of 2
      • Locate the tabs that hold the base cover to the laptop and use a plastic opening tool to gently release the base cover.
      Ask FixBot
    3. Dell Inspiron 17-5755 Display Panel Replacement: step 12, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 12, image 2 of 2
      • Now with the base cover removed, you may lift it off of the laptop and continue.
      Ask FixBot
    4. Dell Inspiron 17-5755 Display Panel Replacement: step 13, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 13, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 13, image 3 of 3
      • Disconnect the hard drive ribbon cable from the laptop by lifting the latch which secures it.
      Ask FixBot
    5. Dell Inspiron 17-5755 Display Panel Replacement: step 14, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the four 8mm screws which secure the hard drive assembly to the laptop.
      Ask FixBot
    6. Dell Inspiron 17-5755 Display Panel Replacement: step 15, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 15, image 2 of 2
      • Carefully remove the hard drive and its assembly from the laptop.
      Ask FixBot
    7. Dell Inspiron 17-5755 Display Panel Replacement: step 16, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 16, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 16, image 3 of 3
      • Remove the 3mm screw which secures the wireless card bracket.
      • After removing the screw, remove the wireless card bracket, along with the antenna cables secured to the wireless card.
      • Afterwards, you may slide and remove the wireless card from the motherboard.
      Ask FixBot
    8. Dell Inspiron 17-5755 Display Panel Replacement: step 17, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 17, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 17, image 3 of 3
      • Gently spread apart the securing clips on each end of the memory-module slot until the memory module pops out.
      • Slide and remove the memory module afterwards.
      Ask FixBot
    9. Dell Inspiron 17-5755 Display Panel Replacement: step 18, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 18, image 2 of 2
      • Use a plastic opening tool to gently pry the CMOS battery found at the bottom right of the laptop out of the socket.
      Ask FixBot
    10. Dell Inspiron 17-5755 Display Panel Replacement: step 19, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 19, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 19, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the 3mm screw which secures the optical-drive assembly to the computer base
      • Turn the computer over and using a plastic opening tool, push the optical-drive assembly out of the optical drive bay.
      • Afterwards, safely pull the optical-drive assembly out of the optical-drive bay.
      Ask FixBot
    11. Dell Inspiron 17-5755 Display Panel Replacement: step 20, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 20, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 20, image 3 of 3
      • Lift the latch securing the optical drive ribbon cable, and disconnect it from the motherboard.
      • Afterwards, use a Phillips #0 screwdriver to remove the four 5mm screws.
      Ask FixBot
    12. Dell Inspiron 17-5755 Display Panel Replacement: step 21, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 21, image 2 of 2
      • Turn over the laptop, and safely disconnect the speaker cable.
      Ask FixBot
    13. Dell Inspiron 17-5755 Display Panel Replacement: step 22, image 1 of 1
      • Remove the antenna cables from the routing guides on the computer base.
      Ask FixBot
    14. Dell Inspiron 17-5755 Display Panel Replacement: step 23, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 23, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the 15 screws that secure the computer base to the palm rest assembly.
      • Afterwards, safely pry the computer base from the palm rest assembly using a plastic opening tool.
      • There are 3 different screws used: Three 2mm screws on the edge of the optical drive, two 3mm screws located where the battery was, and ten 8mm screws.
      Ask FixBot
    15. Dell Inspiron 17-5755 Display Panel Replacement: step 24, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 24, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the 5mm screw that secures the I/O board to the palm-rest assembly.
      Ask FixBot
    16. Dell Inspiron 17-5755 Display Panel Replacement: step 25, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 25, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 25, image 3 of 3
      • Lift the I/O board and turn it over.
      • Afterwards, lift the ZIF latch and disconnect the I/O-board cable from the I/O board.
      Ask FixBot
    17. Dell Inspiron 17-5755 Display Panel Replacement: step 26, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 26, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 26, image 3 of 3
      • Disconnect the fan cable from the motherboard.
      • Use a Phillips #0 screwdriver to remove the heat-sink screws in sequential order, as indicated by the numbers on the heat-sink assembly.
      • Afterwards lift the heat-sink assembly off the motherboard.
      Ask FixBot
    18. Dell Inspiron 17-5755 Display Panel Replacement: step 27, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 27, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 27, image 3 of 3
      • Turn the computer over and open the display as far as possible.
      • Lift the latches for the power button board cable and disconnect it along with the touchpad cable from the motherboard.
      Ask FixBot
    19. Dell Inspiron 17-5755 Display Panel Replacement: step 28, image 1 of 1
      • Close the display and turn the computer over.
      • Proceed to lift the latch which secures the ZIF display cable to the motherboard.
      • Disconnect the display cable from the motherboard.
      Ask FixBot
    20. Dell Inspiron 17-5755 Display Panel Replacement: step 29, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 29, image 2 of 2
      • Use a Phillips# 0 screwdriver to remove the 3mm screw that secures the motherboard to the palm-rest assembly.
      • Afterwards, carefully peel the I/O board cable off the palm-rest assembly.
      Ask FixBot
    21. Dell Inspiron 17-5755 Display Panel Replacement: step 30, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 30, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 30, image 3 of 3
      • Turn the motherboard over.
      • Lift the latch to disconnect the I/O-board cable from the motherboard.
      Ask FixBot
    22. Dell Inspiron 17-5755 Display Panel Replacement: step 31, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 31, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 31, image 3 of 3
      • Disconnect the power-adapter port cable from the motherboard.
      • Afterwards you may safely remove the motherboard from the laptop.
      Ask FixBot
    1. Dell Inspiron 17-5755 Display Panel Replacement, Display Panel: step 32, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement, Display Panel: step 32, image 2 of 2
      • Using a Phillips 0 screwdriver, remove the screw (M2 x 3) the power-adapter port to the palm-rest assembly.
      • Peel off the tape that secures the power-adapter port to the palm-rest assembly.
      Ask FixBot
    2. Dell Inspiron 17-5755 Display Panel Replacement: step 33, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 33, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 33, image 3 of 3
      • Carefully detach the antenna cables from their respective routing guides
      Ask FixBot
    3. Dell Inspiron 17-5755 Display Panel Replacement: step 34, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 34, image 2 of 2
      • Using a Phillips 0 screwdriver, remove the 7 screws (M2.5 x 5) that secure the display hinges to the palm-rest assembly.
      • Detach the display assembly from the palm rest assembly
      Ask FixBot
    4. Dell Inspiron 17-5755 Display Panel Replacement: step 35, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 35, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 35, image 3 of 3
      • Using the tip of your fingers, gently pry off the display bezel from the back-cover
      Ask FixBot
    5. Dell Inspiron 17-5755 Display Panel Replacement: step 36, image 1 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 36, image 2 of 3 Dell Inspiron 17-5755 Display Panel Replacement: step 36, image 3 of 3
      • Using a Phillips 0 screwdriver, remove the 10 screws (M2.5 x 4.5) that secure the display panel to the display back-cover.
      Ask FixBot
    6. Dell Inspiron 17-5755 Display Panel Replacement: step 37, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 37, image 2 of 2
      • Using a Phillips 0 screwdriver, remove the 6 screws (M2 x 3) that secure the display hinges to the display panel.
      Ask FixBot
    7. Dell Inspiron 17-5755 Display Panel Replacement: step 38, image 1 of 2 Dell Inspiron 17-5755 Display Panel Replacement: step 38, image 2 of 2
      • Carefully turn the display assembly around.
      • Gently peel the display cable and disconnect the latch that is found under it.
      Ask FixBot
    8. Dell Inspiron 17-5755 Display Panel Replacement: step 39, image 1 of 1
      • Once the display hinges are removed, your display panel is now ready to be replaced.
      Ask FixBot
Jeff
388 Reputation
3 Guides authored
USF Tampa, Team S6-G1, Lacy Spring 2017 Member of USF Tampa, Team S6-G1, Lacy Spring 2017
USFT-LACY-S17S6G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 92
All Time: 1,655
