Dell Inspiron 17-5749 Back Cover Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
68
All Time:
903
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Dell Inspiron 17-5749 Back Cover Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 17-5749 Back Cover Replacement, Battery: step 1, image 2 of 2
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Turn off power to the laptop.
      • Unplug the charging cable from the laptop.
      • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
      • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
      Ask FixBot
    2. Dell Inspiron 17-5749 Back Cover Replacement: step 2, image 1 of 2 Dell Inspiron 17-5749 Back Cover Replacement: step 2, image 2 of 2
      • First carefully turn the laptop over so you can access the battery.
      • Switch each of the battery latches to the "unlocked" position.
      • Pull battery upwards by the tab to remove from the laptop.
      Ask FixBot
    1. Dell Inspiron 17-5749 Back Cover Replacement, Back Cover: step 3, image 1 of 3 Dell Inspiron 17-5749 Back Cover Replacement, Back Cover: step 3, image 2 of 3 Dell Inspiron 17-5749 Back Cover Replacement, Back Cover: step 3, image 3 of 3
      • Remove the two 5.5mm screws that secure the base cover to the computer's base.
      • Using the plastic opening tool, carefully pry open the base cover starting from the center.
      • Lift the base cover upwards to remove and set it aside.
      Ask FixBot
Christopher Tran
1,162 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 68
All Time: 903
