Dell Inspiron 17-5748 Keyboard Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
27
Past 30 Days:
79
All Time:
1,254
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show how to access and replace the keyboard in this laptop. Simple tools are required. Be gentle when removing parts with ribbon cables.
Parts
Tools
    1. Dell Inspiron 17-5748 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop upside down.
      • Locate the battery lock latches.
      Ask FixBot
    2. Dell Inspiron 17-5748 Keyboard Replacement: step 2, image 1 of 1
      • Slide both lock latches to the unlocked position.
      Ask FixBot
    3. Dell Inspiron 17-5748 Keyboard Replacement: step 3, image 1 of 1
      • Lift the battery up and out of the laptop battery socket.
      Ask FixBot
    1. Dell Inspiron 17-5748 Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Open the laptop and locate the keyboard.
      Ask FixBot
    2. Dell Inspiron 17-5748 Keyboard Replacement: step 5, image 1 of 2 Dell Inspiron 17-5748 Keyboard Replacement: step 5, image 2 of 2
      • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
      • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
      Ask FixBot
    3. Dell Inspiron 17-5748 Keyboard Replacement: step 6, image 1 of 2 Dell Inspiron 17-5748 Keyboard Replacement: step 6, image 2 of 2
      • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
      • Lift the keyboard partially and flip it over.
      Ask FixBot
    4. Dell Inspiron 17-5748 Keyboard Replacement: step 7, image 1 of 2 Dell Inspiron 17-5748 Keyboard Replacement: step 7, image 2 of 2
      • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
      • Gently detach the cable and the keyboard from the laptop.
      Ask FixBot
Justine Vaca
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 27
Past 30 Days: 79
All Time: 1,254
