Dell Inspiron 17-3721 Keyboard Replacement
  1. Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Dell Inspiron 17-3721 Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
    Ask FixBot
  2. Dell Inspiron 17-3721 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron 17-3721 Keyboard Replacement: step 2, image 2 of 2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
    Ask FixBot
Kevin Prairie
466 Reputation
4 Guides authored
1 Guide Comment
Wow that was easy! Thanks :D
Isaac Pettis - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 36
All Time: 746
