Dell Inspiron 16-7610 RAM Replacement
    1. Dell Inspiron 16-7610 RAM Replacement, Back Case: step 1, image 1 of 2 Dell Inspiron 16-7610 RAM Replacement, Back Case: step 1, image 2 of 2
      • Flip the device over, so the backside is facing up.
      • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
      • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
      • The last two screws should remain in the back case and can't be removed.
      • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
      Ask FixBot
    2. Dell Inspiron 16-7610 RAM Replacement: step 2, image 1 of 1
      • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
      • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
      • Remove the back case from the device.
      Ask FixBot
    1. Dell Inspiron 16-7610 RAM Replacement, RAM: step 3, image 1 of 3 Dell Inspiron 16-7610 RAM Replacement, RAM: step 3, image 2 of 3 Dell Inspiron 16-7610 RAM Replacement, RAM: step 3, image 3 of 3
      • Flip the plastic cover over to reveal the RAM stick. Do not pull the plastic cover off.
      • Pull the two RAM retaining arms away from the center of the RAM stick.
      • The RAM stick should "pop" up slightly from its socket.
      • Pull the RAM stick out of the socket. Repeat for each of the RAM sticks you are replacing.
      • Align your new RAM sticks on to the sockets when installing them to prevent any damage to the pins below.
      Ask FixBot
Michael Torres
157 Reputation
2 Guides authored
Gateway, Team 1-3, Pee Spring 2023 Member of Gateway, Team 1-3, Pee Spring 2023
GCC-PEE-S23S1G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 59
All Time: 1,010
