Dell Inspiron 16 7610 Back Case Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
87
All Time:
1,599
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Follow this guide to remove the back case of your Dell Inspiron 16 7610 to access the internals of your laptop or replace it if it has broken or cracked.
Tools
    1. Dell Inspiron 16 7610 Back Case Replacement, Back Case: step 1, image 1 of 2 Dell Inspiron 16 7610 Back Case Replacement, Back Case: step 1, image 2 of 2
      • Flip the device over, so the backside is facing up.
      • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
      • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
      • The last two screws should remain in the back case and can't be removed.
      • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
      Ask FixBot
    2. Dell Inspiron 16 7610 Back Case Replacement: step 2, image 1 of 1
      • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
      • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
      • Remove the back case from the device.
      Ask FixBot
Jerson Gomez
898 Reputation
3 Guides authored
Gateway, Team 1-3, Pee Spring 2023 Member of Gateway, Team 1-3, Pee Spring 2023
GCC-PEE-S23S1G3
4 Members
72 Guides authored
1 Guide Comment
Followed instructions. No clips broken but still cannot close the back cover. There’s a small gab in between the mouse and the cover when I close it.
Enos Nii Armah - Reply Share
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 87
All Time: 1,599
