Dell Inspiron 15z 5523 Memory Module Replacement
    1. Dell Inspiron 15z 5523 Memory Module Replacement, Loosen the Screw: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
      • Close the display and turn the computer over.
      • Loosen the captive screw that secures the memory-module cover to the computer base.
      Ask FixBot
    2. Dell Inspiron 15z 5523 Memory Module Replacement, Lifting the Module Cover: step 2, image 1 of 1
      • Using your fingertips, lift the memory-module cover out of the slots on the computer base.
      Ask FixBot
    3. Dell Inspiron 15z 5523 Memory Module Replacement, Popping up the Memory Module: step 3, image 1 of 1
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
      Ask FixBot
      • Align the notch on the NEW memory module with the tab on the memory-module connector.
      Ask FixBot
    4. Dell Inspiron 15z 5523 Memory Module Replacement, Sliding the Memory Module: step 5, image 1 of 1
      • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
      • NOTE: If you do not hear the click, remove the memory module and reinstall it.
      Ask FixBot
    5. Dell Inspiron 15z 5523 Memory Module Replacement, Slide the Tabs: step 6, image 1 of 1
      • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
      Ask FixBot
    6. Dell Inspiron 15z 5523 Memory Module Replacement, Tighten the Screw: step 7, image 1 of 1
      • Tighten the captive screw that secures the memory-module cover to the computer base.
      Ask FixBot
Finish Line
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 55
All Time: 459
