Dell Inspiron 15R SE 7520 Memory Module Replacement
    1. Dell Inspiron 15R SE 7520 Memory Module Replacement, Popping up the Memory Module: step 1, image 1 of 2 Dell Inspiron 15R SE 7520 Memory Module Replacement, Popping up the Memory Module: step 1, image 2 of 2
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
      • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
      Ask FixBot
    2. Dell Inspiron 15R SE 7520 Memory Module Replacement, Remove the Memory Module: step 2, image 1 of 1
      • Remove the memory module from the memory-module connector.
      Ask FixBot
    3. Dell Inspiron 15R SE 7520 Memory Module Replacement, Align the Notch: step 3, image 1 of 2 Dell Inspiron 15R SE 7520 Memory Module Replacement, Align the Notch: step 3, image 2 of 2
      • Align the notch on the NEW memory module with the tab on the memory-module connector.
      Ask FixBot
    4. Dell Inspiron 15R SE 7520 Memory Module Replacement, Sliding the Memory Module: step 4, image 1 of 1
      • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      Ask FixBot
Finish Line
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 61
All Time: 579
