Up to 20% off select tools
Dell Inspiron 15R RAM Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
90
All Time:
1,154
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The Dell Inspiron is expandable up to 8GB. If the device is running slowly, you can purchase its maximum memory capacity.
    1. Dell Inspiron 15R RAM Replacement, Battery: step 1, image 1 of 1
      • Turn the device over and locate the battery.
      Ask FixBot
    2. Dell Inspiron 15R RAM Replacement: step 2, image 1 of 2 Dell Inspiron 15R RAM Replacement: step 2, image 2 of 2
      • Place thumbs on each latch and push outwards.
      Ask FixBot
    3. Dell Inspiron 15R RAM Replacement: step 3, image 1 of 1
      • Push and slide the battery away from you.
      Ask FixBot
    1. Dell Inspiron 15R RAM Replacement, RAM: step 4, image 1 of 1
      • Locate the RAM compartment on the device and locate the screw on the right hand side.
      Ask FixBot
    2. Dell Inspiron 15R RAM Replacement: step 5, image 1 of 2 Dell Inspiron 15R RAM Replacement: step 5, image 2 of 2
      • Take your screwdriver and loosen the screw. Then remove the cover.
      Ask FixBot
    3. Dell Inspiron 15R RAM Replacement: step 6, image 1 of 3 Dell Inspiron 15R RAM Replacement: step 6, image 2 of 3 Dell Inspiron 15R RAM Replacement: step 6, image 3 of 3
      • Place both thumbs on the latches and push outward. The RAM card will pop up.
      Ask FixBot
    4. Dell Inspiron 15R RAM Replacement: step 7, image 1 of 1
      • Carefully hold RAM card from the sides and pull away.
      Ask FixBot
    5. Dell Inspiron 15R RAM Replacement: step 8, image 1 of 2 Dell Inspiron 15R RAM Replacement: step 8, image 2 of 2
      • Repeats steps 6 and 7 for the second RAM card.
      Ask FixBot
3 other people completed this guide.
Author
with
Trixie Gonzalez
843 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 90
All Time: 1,154
