Up to 20% off select tools
Dell Inspiron 15R N5110 Memory Module Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
61
All Time:
853
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Memory Module.
    1. Dell Inspiron 15R N5110 Memory Module Replacement, Loosen the Screw: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
      • Loosen the captive screw that secures the memory-module cover to the computer base.
      Ask FixBot
    2. Dell Inspiron 15R N5110 Memory Module Replacement, Lifting the Memory Module Cover: step 2, image 1 of 1
      • Using your fingertips, lift the memory-module cover out of the slots on the computer base.
      Ask FixBot
    3. Dell Inspiron 15R N5110 Memory Module Replacement, Popping up the Memory Module: step 3, image 1 of 2 Dell Inspiron 15R N5110 Memory Module Replacement, Popping up the Memory Module: step 3, image 2 of 2
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
      Ask FixBot
    4. Dell Inspiron 15R N5110 Memory Module Replacement, Remove the Memory Module: step 4, image 1 of 1
      • Remove the memory module from the memory-module connector.
      Ask FixBot
      • Align the notch on the NEW memory module with the tab on the memory-module connector.
      Ask FixBot
    5. Dell Inspiron 15R N5110 Memory Module Replacement, Sliding the Memory Module: step 6, image 1 of 1
      • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
      • NOTE: If you do not hear the click, remove the memory module and reinstall it.
      Ask FixBot
    6. Dell Inspiron 15R N5110 Memory Module Replacement, Slide the Tabs: step 7, image 1 of 1
      • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
      Ask FixBot
    7. Dell Inspiron 15R N5110 Memory Module Replacement, Tighten the Screw: step 8, image 1 of 1
      • Tighten the captive screw that secures the memory-module cover to the computer base.
      Ask FixBot
Finish Line
Author
with
Terrence15
80,173 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 61
All Time: 853
