Dell Inspiron 1564 Hard Drive Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
93
All Time:
2,464
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This will show how to replace the hard disk drive in a Dell Inspiron 1564 laptop.
Tools
    1. Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: step 1, image 1 of 2 Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: step 1, image 2 of 2
      • Locate battery latch on bottom of computer and slide to right.
      • While holding battery latch, pull the battery away from device and the battery will come free.
      Ask FixBot
    2. Dell Inspiron 1564 Hard Drive Replacement, Remove Bottom Cover Screws: step 2, image 1 of 1
      • With a J0 screwdriver bit, loosen all screws from the backing above the battery latch and remove the covering.
      Ask FixBot
    3. Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: step 3, image 1 of 2 Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: step 3, image 2 of 2
      • Locate the three 4mm screws securing the hard drive and unscrew them with a J0 screwdriver.
      • Slide the hard drive to the left to unplug the SATA data and SATA power cables, then gently pry upwards and pull the drive away from device.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 93
All Time: 2,464
