Up to 20% off select tools
Dell Inspiron 1546 Memory Module Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
9
Past 30 Days:
50
All Time:
398
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 40 seconds
Difficulty: Very easy
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Memory Module.
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      Ask FixBot
    1. Dell Inspiron 1546 Memory Module Replacement, Popping up the Memory Module: step 2, image 1 of 1
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      Ask FixBot
    2. Dell Inspiron 1546 Memory Module Replacement, Align the Notch: step 3, image 1 of 2 Dell Inspiron 1546 Memory Module Replacement, Align the Notch: step 3, image 2 of 2
      • Align the notch in the NEW memory module with the tab in the memory module connector.
      Ask FixBot
    3. Dell Inspiron 1546 Memory Module Replacement, Sliding the Module: step 4, image 1 of 1
      • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      Ask FixBot
Finish Line
Author
with
Terrence15
80,173 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 50
All Time: 398
