Dell Inspiron 1545 Power Button Board Replacement
    1. Dell Inspiron 1545 Power Button Board Replacement, Power Button Board: step 1, image 1 of 1
      • Turn the laptop off and disconnect it from all power sources.
      • Turn the laptop over so that the bottom is facing upwards.
      Ask FixBot
    2. Dell Inspiron 1545 Power Button Board Replacement: step 2, image 1 of 1
      • Slide the release latch while simultaneously pulling the battery outwards.
      Ask FixBot
    3. Dell Inspiron 1545 Power Button Board Replacement: step 3, image 1 of 1
      • Slide the battery completely out of the bay.
      Ask FixBot
    4. Dell Inspiron 1545 Power Button Board Replacement: step 4, image 1 of 1
      • Once the battery has been removed, take out the two screws (3mm Phillips #1) beneath it. These screws hold the center control cover in place.
      Ask FixBot
    5. Dell Inspiron 1545 Power Button Board Replacement: step 5, image 1 of 1
      • Flip the laptop back over to the front and push the screen open as far as possible.
      Ask FixBot
    6. Dell Inspiron 1545 Power Button Board Replacement: step 6, image 1 of 3 Dell Inspiron 1545 Power Button Board Replacement: step 6, image 2 of 3 Dell Inspiron 1545 Power Button Board Replacement: step 6, image 3 of 3
      • The center control cover is very fragile; be careful when prying it off.
      • Pry the center control cover off of the laptop using a plastic opening tool. On the right side of the cover, there is a small divot to help you start removing the cover.
      • Carefully lift the central control cover away from the laptop.
      Ask FixBot
    7. Dell Inspiron 1545 Power Button Board Replacement: step 7, image 1 of 1
      • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
      Ask FixBot
    8. Dell Inspiron 1545 Power Button Board Replacement: step 8, image 1 of 1
      • Be careful when pulling the keyboard away from the laptop, you may damage the connector holding it to the motherboard.
      • Using your hands, push the keyboard out and away from the laptop.
      Ask FixBot
    9. Dell Inspiron 1545 Power Button Board Replacement: step 9, image 1 of 2 Dell Inspiron 1545 Power Button Board Replacement: step 9, image 2 of 2
      • Lift the connector latch to remove the keyboard cable from the motherboard.
      • Lift the keyboard away from the laptop.
      Ask FixBot
    10. Dell Inspiron 1545 Power Button Board Replacement: step 10, image 1 of 1
      • Lift the connector latch to remove the power button board from the motherboard.
      • Pull on the blue plastic tab to help prevent causing any damage to the connector.
      Ask FixBot
    11. Dell Inspiron 1545 Power Button Board Replacement: step 11, image 1 of 1
      • Pry the power button board out with your finger.
      • Pull the power button board away from the laptop.
      Ask FixBot
Michael Hill
193 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 22
All Time: 2,767
