Dell Inspiron 1545 Keyboard Replacement
    1. Dell Inspiron 1545 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
      • Turn the laptop over to its back.
      Ask FixBot
    2. Dell Inspiron 1545 Keyboard Replacement: step 2, image 1 of 1
      • Slide the release latch while simultaneously pulling backwards on the battery.
      Ask FixBot
    3. Dell Inspiron 1545 Keyboard Replacement: step 3, image 1 of 1
      • Slide the battery out of the battery bay.
      Ask FixBot
    1. Dell Inspiron 1545 Keyboard Replacement, Base Cover: step 4, image 1 of 1
      • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
      • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
      Ask FixBot
    2. Dell Inspiron 1545 Keyboard Replacement: step 5, image 1 of 2 Dell Inspiron 1545 Keyboard Replacement: step 5, image 2 of 2
      • Carefully lift the base cover vertically away from the laptop.
      Ask FixBot
    1. Dell Inspiron 1545 Keyboard Replacement, Center Control Cover: step 6, image 1 of 1
      • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
      Ask FixBot
    2. Dell Inspiron 1545 Keyboard Replacement: step 7, image 1 of 1
      • Flip the laptop over to the front and open the display as far as possible.
      Ask FixBot
    3. Dell Inspiron 1545 Keyboard Replacement: step 8, image 1 of 3 Dell Inspiron 1545 Keyboard Replacement: step 8, image 2 of 3 Dell Inspiron 1545 Keyboard Replacement: step 8, image 3 of 3
      • The Center Control Cover is VERY fragile, be careful when using prying tools.
      • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
      • Carefully lift the Center Control Cover away from the laptop.
      Ask FixBot
    1. Dell Inspiron 1545 Keyboard Replacement, Keyboard: step 9, image 1 of 1
      • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
      Ask FixBot
    2. Dell Inspiron 1545 Keyboard Replacement: step 10, image 1 of 1
      • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
      • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
      Ask FixBot
    3. Dell Inspiron 1545 Keyboard Replacement: step 11, image 1 of 1
      • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
      Ask FixBot
    4. Dell Inspiron 1545 Keyboard Replacement: step 12, image 1 of 1
      • Lift the keyboard up and away from the laptop.
      Ask FixBot
15 other people completed this guide.
Nathan Lemay
3,160 Reputation
15 Guides authored
Cal Poly, Team 9-14, Regan Spring 2014 Member of Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Members
180 Guides authored
3 Guide Comments
Step 4 and 5 are not needed.
James Thrun - Reply Share
Steps 4 and 5 are unnecessary for removing the keyboard. Other than that, well done.
lee - Reply Share
The connector latch is broken. What should I do?
Mjeed - Reply Share
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 119
All Time: 8,225
