Up to 20% off select tools
Dell Inspiron 1545 Display Replacement
Views: 6.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
95
All Time:
6,824
Comments: 7
4 comments on steps, 3 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Parts
Tools
Introduction
Go to step 1 ↓
There are many parts that can go bad within a display. This guide does not necessarily cover the replacement of all the smaller pieces, but it does allow you to access those parts.
    1. Dell Inspiron 1545 Display Replacement, Battery: step 1, image 1 of 1
      • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
      • Turn the laptop over to its back.
      Ask FixBot
    2. Dell Inspiron 1545 Display Replacement: step 2, image 1 of 1
      • Slide the release latch while simultaneously pulling backwards on the battery.
      Ask FixBot
    3. Dell Inspiron 1545 Display Replacement: step 3, image 1 of 1
      • Slide the battery out of the battery bay.
      Ask FixBot
    1. Dell Inspiron 1545 Display Replacement, Center Control Cover: step 4, image 1 of 1
      • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
      Ask FixBot
    2. Dell Inspiron 1545 Display Replacement: step 5, image 1 of 1
      • Flip the laptop over to the front and open the display as far as possible.
      Ask FixBot
    3. Dell Inspiron 1545 Display Replacement: step 6, image 1 of 3 Dell Inspiron 1545 Display Replacement: step 6, image 2 of 3 Dell Inspiron 1545 Display Replacement: step 6, image 3 of 3
      • The Center Control Cover is VERY fragile, be careful when using prying tools.
      • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
      • Carefully lift the Center Control Cover away from the laptop.
      Ask FixBot
    1. Dell Inspiron 1545 Display Replacement, Keyboard: step 7, image 1 of 1
      • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
      Ask FixBot
    2. Dell Inspiron 1545 Display Replacement: step 8, image 1 of 1
      • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
      • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
      Ask FixBot
    3. Dell Inspiron 1545 Display Replacement: step 9, image 1 of 1
      • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
      Ask FixBot
    4. Dell Inspiron 1545 Display Replacement: step 10, image 1 of 1
      • Lift the keyboard up and away from the laptop.
      Ask FixBot
    1. Dell Inspiron 1545 Display Replacement, Display: step 11, image 1 of 1
      • Remove the two screws (5.5mm, Phillips #1) from the laptop base.
      Ask FixBot
    2. Dell Inspiron 1545 Display Replacement: step 12, image 1 of 1
      • Remove black and white wires from the WLAN that lead to the display by pulling straight up.
      • Unwind the wires so they can be freely pulled through in the next step.
      Ask FixBot
    3. Dell Inspiron 1545 Display Replacement: step 13, image 1 of 1
      • Turn the laptop over to its standard position.
      • Disconnect the Wed cable and Camera1 cable from the respective Motherboard connectors as marked. Unsecure the wires so they are loose.
      • Pull the black and white wires previously connected to the WLAN through the hole.
      Ask FixBot
    4. Dell Inspiron 1545 Display Replacement: step 14, image 1 of 1
      • Remove the Camera1 cable, the Wed cable, and the black and white wires from the routing guides.
      • Remove the four screws (5mm Phillips #1) (two on either side) that secure the display assembly.
      Ask FixBot
    5. Dell Inspiron 1545 Display Replacement: step 15, image 1 of 1
      • Lift the display assembly off the computer.
      Ask FixBot
11 other people completed this guide.
Author
with
Nathan Lemay
3,172 Reputation
15 Guides authored
Cal Poly, Team 9-14, Regan Spring 2014 Member of Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Members
180 Guides authored
3 Guide Comments
wow that is really good
Mck - Isolutions - Reply Share
AWESOME, but how to know if display is faulty or some issue in the other device causing blank screen
Kumar Bhrigu - Reply Share
put it back toghther, then plug in a external monitor
Feyrowan - Reply Share
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 95
All Time: 6,824
