Up to 20% off select tools
Dell Inspiron 1545 Computer Processing Unit Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
108
All Time:
3,687
Comments: 1
1 comment on steps.
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Parts
Tools
Introduction
Go to step 1 ↓
This guide will be utilized mainly if your CPU has gone bad and your laptop is essentially nonfunctional.
    1. Dell Inspiron 1545 Computer Processing Unit Replacement, Battery: step 1, image 1 of 1
      • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
      • Turn the laptop over to its back.
      Ask FixBot
    2. Dell Inspiron 1545 Computer Processing Unit Replacement: step 2, image 1 of 1
      • Slide the release latch while simultaneously pulling backwards on the battery.
      Ask FixBot
    3. Dell Inspiron 1545 Computer Processing Unit Replacement: step 3, image 1 of 1
      • Slide the battery out of the battery bay.
      Ask FixBot
    1. Dell Inspiron 1545 Computer Processing Unit Replacement, Base Cover: step 4, image 1 of 1
      • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
      • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
      Ask FixBot
    2. Dell Inspiron 1545 Computer Processing Unit Replacement: step 5, image 1 of 2 Dell Inspiron 1545 Computer Processing Unit Replacement: step 5, image 2 of 2
      • Carefully lift the base cover vertically away from the laptop.
      Ask FixBot
    1. Dell Inspiron 1545 Computer Processing Unit Replacement, CPU Heat Sink: step 6, image 1 of 1
      • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
      • These screws are held in place by a washer so you should not be able to completely remove the screws.
      Ask FixBot
    2. Dell Inspiron 1545 Computer Processing Unit Replacement: step 7, image 1 of 1
      • Pull up on the Heat Sink unit to remove it.
      Ask FixBot
    1. Dell Inspiron 1545 Computer Processing Unit Replacement, Computer Processing Unit: step 8, image 1 of 1
      • Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
      Ask FixBot
    2. Dell Inspiron 1545 Computer Processing Unit Replacement: step 9, image 1 of 1
      • The CPU is very fragile and has thin pins.
      • Remove the CPU by pulling straight upward and away from the laptop.
      Ask FixBot
8 other people completed this guide.
Author
with
Nathan Lemay
3,172 Reputation
15 Guides authored
Cal Poly, Team 9-14, Regan Spring 2014 Member of Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 108
All Time: 3,687
