Dell Inspiron 1545 Center Control Cover Replacement
    1. Dell Inspiron 1545 Center Control Cover Replacement, Battery: step 1, image 1 of 1
      • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
      • Turn the laptop over to its back.
      Ask FixBot
    2. Dell Inspiron 1545 Center Control Cover Replacement: step 2, image 1 of 1
      • Slide the release latch while simultaneously pulling backwards on the battery.
      Ask FixBot
    3. Dell Inspiron 1545 Center Control Cover Replacement: step 3, image 1 of 1
      • Slide the battery out of the battery bay.
      Ask FixBot
    1. Dell Inspiron 1545 Center Control Cover Replacement, Center Control Cover: step 4, image 1 of 1
      • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
      Ask FixBot
    2. Dell Inspiron 1545 Center Control Cover Replacement: step 5, image 1 of 1
      • Flip the laptop over to the front and open the display as far as possible.
      Ask FixBot
    3. Dell Inspiron 1545 Center Control Cover Replacement: step 6, image 1 of 3 Dell Inspiron 1545 Center Control Cover Replacement: step 6, image 2 of 3 Dell Inspiron 1545 Center Control Cover Replacement: step 6, image 3 of 3
      • The Center Control Cover is VERY fragile, be careful when using prying tools.
      • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
      • Carefully lift the Center Control Cover away from the laptop.
      Ask FixBot
2 other people completed this guide.
Nathan Lemay
3,160 Reputation
15 Guides authored
Cal Poly, Team 9-14, Regan Spring 2014 Member of Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 127
All Time: 3,573
