Dell Inspiron 1545 Base Cover Replacement
    1. Dell Inspiron 1545 Base Cover Replacement, Battery: step 1, image 1 of 1
      • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
      • Turn the laptop over to its back.
      Ask FixBot
    2. Dell Inspiron 1545 Base Cover Replacement: step 2, image 1 of 1
      • Slide the release latch while simultaneously pulling backwards on the battery.
      Ask FixBot
    3. Dell Inspiron 1545 Base Cover Replacement: step 3, image 1 of 1
      • Slide the battery out of the battery bay.
      Ask FixBot
    1. Dell Inspiron 1545 Base Cover Replacement, Base Cover: step 4, image 1 of 1
      • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
      • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
      Ask FixBot
    2. Dell Inspiron 1545 Base Cover Replacement: step 5, image 1 of 2 Dell Inspiron 1545 Base Cover Replacement: step 5, image 2 of 2
      • Carefully lift the base cover vertically away from the laptop.
      Ask FixBot
6 other people completed this guide.
Nathan Lemay
3,160 Reputation
15 Guides authored
Cal Poly, Team 9-14, Regan Spring 2014 Member of Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 107
All Time: 3,289
