Dell Inspiron 1525 Wireless Mini-Card Replacement
Views: 9.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
97
All Time:
9,544
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to help you replace the Wireless Mini-Card in a Dell Inspiron 1525.
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Dell Inspiron 1525 Wireless Mini-Card Replacement, Battery: step 1, image 1 of 1
      • Locate the battery release switch on the bottom of the laptop.
      Ask FixBot
    2. Dell Inspiron 1525 Wireless Mini-Card Replacement: step 2, image 1 of 2 Dell Inspiron 1525 Wireless Mini-Card Replacement: step 2, image 2 of 2
      • Slide the battery release switch away from the lock symbol until you hear the battery click.
      • Slide the battery towards the back of the laptop until it comes free.
      Ask FixBot
    1. Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: step 3, image 1 of 2 Dell Inspiron 1525 Wireless Mini-Card Replacement, Bottom Cover: step 3, image 2 of 2
      • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
      • The screws may only need to be loosened, as they are generally retained by plastic washers.
      • Remove the bottom panel.
      Ask FixBot
    1. Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: step 4, image 1 of 2 Dell Inspiron 1525 Wireless Mini-Card Replacement, Wireless Mini-Card: step 4, image 2 of 2
      • Use the flat end of a spudger to gently pry the black and white antenna connectors off the Wireless Mini-Card.
      Ask FixBot
    2. Dell Inspiron 1525 Wireless Mini-Card Replacement: step 5, image 1 of 2 Dell Inspiron 1525 Wireless Mini-Card Replacement: step 5, image 2 of 2
      • Remove the 3.70 mm Phillips #1 screw securing the card to the laptop.
      • The card will tilt up when you remove the screw.
      • Slide the card straight out.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 97
All Time: 9,544
