Dell Inspiron 1525 Display Assembly Replacement
    1. Dell Inspiron 1525 Display Assembly Replacement, Battery: step 1, image 1 of 1
      • Locate the battery release switch on the bottom of the laptop.
      Ask FixBot
    2. Dell Inspiron 1525 Display Assembly Replacement: step 2, image 1 of 2 Dell Inspiron 1525 Display Assembly Replacement: step 2, image 2 of 2
      • Slide the battery release switch away from the lock symbol until you hear the battery click.
      • Slide the battery towards the back of the laptop until it comes free.
      Ask FixBot
    1. Dell Inspiron 1525 Display Assembly Replacement, Central Control Cover: step 3, image 1 of 1
      • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
      Ask FixBot
    2. Dell Inspiron 1525 Display Assembly Replacement: step 4, image 1 of 3 Dell Inspiron 1525 Display Assembly Replacement: step 4, image 2 of 3 Dell Inspiron 1525 Display Assembly Replacement: step 4, image 3 of 3
      • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
      • Carefully pull the central control cover up along its edges.
      • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
      Ask FixBot
    3. Dell Inspiron 1525 Display Assembly Replacement: step 5, image 1 of 3 Dell Inspiron 1525 Display Assembly Replacement: step 5, image 2 of 3 Dell Inspiron 1525 Display Assembly Replacement: step 5, image 3 of 3
      • Peel back the silver tape securing the ribbon cable to the cover.
      • Pull the small brown latch on the ribbon cable connector out.
      • Disconnect the ribbon cable to completely free the central control cover.
      Ask FixBot
    1. Dell Inspiron 1525 Display Assembly Replacement, Keyboard: step 6, image 1 of 2 Dell Inspiron 1525 Display Assembly Replacement, Keyboard: step 6, image 2 of 2
      • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
      • Gently slide the keyboard towards the display until the tabs on its front side are free.
      • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
      Ask FixBot
    2. Dell Inspiron 1525 Display Assembly Replacement: step 7, image 1 of 2 Dell Inspiron 1525 Display Assembly Replacement: step 7, image 2 of 2
      • Use a spudger to gently lift the ribbon cable retaining flap.
      • Disconnect the ribbon cable.
      • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
      Ask FixBot
    1. Dell Inspiron 1525 Display Assembly Replacement, Bottom Cover: step 8, image 1 of 2 Dell Inspiron 1525 Display Assembly Replacement, Bottom Cover: step 8, image 2 of 2
      • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
      • The screws may only need to be loosened, as they are generally retained by plastic washers.
      • Remove the bottom panel.
      Ask FixBot
    1. Dell Inspiron 1525 Display Assembly Replacement, Display Assembly: step 9, image 1 of 3 Dell Inspiron 1525 Display Assembly Replacement, Display Assembly: step 9, image 2 of 3 Dell Inspiron 1525 Display Assembly Replacement, Display Assembly: step 9, image 3 of 3
      • Disconnect the five antennas from their respective cards.
      • De-route the antennas from their routing retainers.
      Ask FixBot
    2. Dell Inspiron 1525 Display Assembly Replacement: step 10, image 1 of 1
      • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
      • The screw holes will be denoted by an embossed "D" by the hole.
      Ask FixBot
    3. Dell Inspiron 1525 Display Assembly Replacement: step 11, image 1 of 3 Dell Inspiron 1525 Display Assembly Replacement: step 11, image 2 of 3 Dell Inspiron 1525 Display Assembly Replacement: step 11, image 3 of 3
      • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
      • Carefully release the connector from its retaining tabs.
      Ask FixBot
    4. Dell Inspiron 1525 Display Assembly Replacement: step 12, image 1 of 2 Dell Inspiron 1525 Display Assembly Replacement: step 12, image 2 of 2
      • Push the antenna wires up through their hole in the bottom case half.
      • Release the antennas from their retaining tabs on the upper case.
      Ask FixBot
    5. Dell Inspiron 1525 Display Assembly Replacement: step 13, image 1 of 2 Dell Inspiron 1525 Display Assembly Replacement: step 13, image 2 of 2
      • Disconnect the flat LCD ribbon cable by pulling it up by the tab.
      • Free the ribbon cable from its retaining clips.
      Ask FixBot
    6. Dell Inspiron 1525 Display Assembly Replacement: step 14, image 1 of 1
      • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
      • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
      • Remove the display assembly from the laptop.
      Ask FixBot
8 other people completed this guide.
1 Guide Comment
Hi There,
Thanks for the great article. Can you please advise what is the part number (LCD number). For example I have LTN156AT17-101 for my Inspiron N5110. I am actually planning to use the screen from 1525 to replace the one in N5110. Are they both same connector type? Thanks.
Zaheer Meerja - Reply Share
Past 24 Hours: 6
Past 7 Days: 35
Past 30 Days: 122
All Time: 10,554
