Dell Inspiron 1521 Hard Drive Replacement
    1. Dell Inspiron 1521 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Rotate the laptop so its bottom is facing up.
      Ask FixBot
    2. Dell Inspiron 1521 Hard Drive Replacement: step 2, image 1 of 3 Dell Inspiron 1521 Hard Drive Replacement: step 2, image 2 of 3 Dell Inspiron 1521 Hard Drive Replacement: step 2, image 3 of 3
      • Identify the lock mechanisms holding the battery in place.
      • Slide each button outward with your fingers to disengage the battery.
      • Pull the battery off with your hand to separate it from the laptop.
      Ask FixBot
    1. Dell Inspiron 1521 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Dell Inspiron 1521 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
      • Locate the four 4 mm Phillips #1 screws that secure the hard drive to the laptop. Each of the screws has a white cylinder next to it.
      • Remove these four screws with a Phillips #1 screwdriver.
      Ask FixBot
    2. Dell Inspiron 1521 Hard Drive Replacement: step 4, image 1 of 3 Dell Inspiron 1521 Hard Drive Replacement: step 4, image 2 of 3 Dell Inspiron 1521 Hard Drive Replacement: step 4, image 3 of 3
      • Once you've made sure all four screws are removed slide the hard drive out with your hand.
      Ask FixBot
3 other people completed this guide.
Rogelio Ordonez
54 Reputation
2 Guides authored
Cal Poly, Team 15-47, Forte Fall 2012 Member of Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 4
Past 30 Days: 28
All Time: 3,837
