Dell Inspiron 1521 Bottom Panel Replacement
    1. Dell Inspiron 1521 Bottom Panel Replacement, Battery: step 1, image 1 of 1
      • Rotate the laptop so its bottom is facing up.
      Ask FixBot
    2. Dell Inspiron 1521 Bottom Panel Replacement: step 2, image 1 of 3 Dell Inspiron 1521 Bottom Panel Replacement: step 2, image 2 of 3 Dell Inspiron 1521 Bottom Panel Replacement: step 2, image 3 of 3
      • Identify the lock mechanisms holding the battery in place.
      • Slide each button outward with your fingers to disengage the battery.
      • Pull the battery off with your hand to separate it from the laptop.
      Ask FixBot
    1. Dell Inspiron 1521 Bottom Panel Replacement, Bottom Panel: step 3, image 1 of 2 Dell Inspiron 1521 Bottom Panel Replacement, Bottom Panel: step 3, image 2 of 2
      • Locate the thirteen 10 mm Phillips #1 screws securing the bottom panel of the laptop.
      • Remove the thirteen indicated screws with a Phillips #1 screwdriver.
      • With the screws removed you can now remove the panel underneath keyboard.
      Ask FixBot
2 other people completed this guide.
Erik Sanchez
21 Reputation
1 Guide authored
Cal Poly, Team 15-47, Forte Fall 2012 Member of Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 28
All Time: 1,512
