Dell Inspiron 1520 Memory Modules Replacement
    1. Dell Inspiron 1520 Memory Modules Replacement, Lifting the Memory Module: step 1, image 1 of 1
      • Follow the procedures in Before You Begin.
      • Lift the memory module cover but do not remove it.
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      Ask FixBot
    2. Dell Inspiron 1520 Memory Modules Replacement, Popping up the Memory Module: step 2, image 1 of 1
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      Ask FixBot
    3. Dell Inspiron 1520 Memory Modules Replacement, Remove the Module: step 3, image 1 of 1
      • Remove the module from the connector.
      Ask FixBot
    4. Dell Inspiron 1520 Memory Modules Replacement, DIMM B Memory Module: step 4, image 1 of 1
      • Turn the computer over.
      • Loosen the captive screw on the memory module cover, then remove the cover and set it aside.
      Ask FixBot
    5. Dell Inspiron 1520 Memory Modules Replacement, Popping up the Memory Module: step 5, image 1 of 2 Dell Inspiron 1520 Memory Modules Replacement, Popping up the Memory Module: step 5, image 2 of 2
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
      Ask FixBot
    6. Dell Inspiron 1520 Memory Modules Replacement, Remove the Memory Module: step 6, image 1 of 1
      • Remove the memory module from the connector.
      Ask FixBot
    7. Dell Inspiron 1520 Memory Modules Replacement, Replacing the DIMM A Memory Module: step 7, image 1 of 2 Dell Inspiron 1520 Memory Modules Replacement, Replacing the DIMM A Memory Module: step 7, image 2 of 2
      • Align the notch in the NEW memory module edge connector with the tab in the connector slot.
      Ask FixBot
    8. Dell Inspiron 1520 Memory Modules Replacement, Sliding the Memory Module: step 8, image 1 of 1
      • Slide the memory module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot. No error message indicates this failure.
      Ask FixBot
    9. Dell Inspiron 1520 Memory Modules Replacement, Replace the Memory Module Cover: step 9, image 1 of 1
      • Replace the memory module cover.
      Ask FixBot
    10. Dell Inspiron 1520 Memory Modules Replacement, Replacing DIMM B Memory Module: step 10, image 1 of 1
      Ask FixBot
    11. Dell Inspiron 1520 Memory Modules Replacement, Align the Notch: step 11, image 1 of 2 Dell Inspiron 1520 Memory Modules Replacement, Align the Notch: step 11, image 2 of 2
      • Align the notch in the module edge connector with the tab in the connector slot.
      Ask FixBot
    12. Dell Inspiron 1520 Memory Modules Replacement, Sliding the Module: step 12, image 1 of 1
      • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
      Ask FixBot
    13. Dell Inspiron 1520 Memory Modules Replacement, Replace the Module Cover: step 13, image 1 of 1
      • NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
      • Replace the memory module cover and tighten the screw.
      Ask FixBot
Finish Line
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 76
All Time: 772
