Dell Inspiron 1501 Optical Drive Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
57
All Time:
706
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to remove the optical disc drive from your device.
Tools
    1. Dell Inspiron 1501 Optical Drive Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 1501 Optical Drive Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 1501 Optical Drive Replacement, Battery: step 1, image 3 of 3
      • Place the laptop facedown with the battery facing you.
      • Push the switch above the battery to the right and hold it in that position.
      • Lift the battery using the grip on the top and remove it from its socket.
      Ask FixBot
    1. Dell Inspiron 1501 Optical Drive Replacement, Optical Drive: step 2, image 1 of 2 Dell Inspiron 1501 Optical Drive Replacement, Optical Drive: step 2, image 2 of 2
      • Remove the JIS #1 8mm screw from above the upper right corner of where the battery was.
      Ask FixBot
    2. Dell Inspiron 1501 Optical Drive Replacement: step 3, image 1 of 1
      • Pull the optical drive out.
      Ask FixBot
2 other people completed this guide.
Ravon Williams
184 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 57
All Time: 706
