Up to 20% off select tools
Dell Inspiron 1501 Memory Modules Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
49
All Time:
738
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 4 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Memory Modules.
    1. Dell Inspiron 1501 Memory Modules Replacement, Turn the Computer Over: step 1, image 1 of 1
      Ask FixBot
    2. Dell Inspiron 1501 Memory Modules Replacement, Loosen the Screws: step 2, image 1 of 1
      • Loosen the two captive screws on the memory module/modem cover and remove the cover.
      Ask FixBot
    3. Dell Inspiron 1501 Memory Modules Replacement, Popping up the Memory Module: step 3, image 1 of 1
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the securing clips that secure the memory module.
      • NOTICE: Handle memory modules by their edges, and do not touch the components on a module.
      Ask FixBot
    4. Dell Inspiron 1501 Memory Modules Replacement, Popping up the Memory Module: step 4, image 1 of 1
      • Remove the module from the connector at a 45-degree angle.
      Ask FixBot
    5. Dell Inspiron 1501 Memory Modules Replacement, Align the Notch: step 5, image 1 of 1
      • Align the notch in the module edge connector with the tab in the connector slot.
      Ask FixBot
    6. Dell Inspiron 1501 Memory Modules Replacement, Sliding the Module: step 6, image 1 of 1
      • Slide the NEW module firmly into the slot at a 45-degree angle, and lower the module until it clicks into place. If you do not feel the click, remove the module and reinstall it.
      Ask FixBot
    7. Dell Inspiron 1501 Memory Modules Replacement, Replace the Modem Cover: step 7, image 1 of 2 Dell Inspiron 1501 Memory Modules Replacement, Replace the Modem Cover: step 7, image 2 of 2
      • Replace the memory module/modem cover and tighten the captive screws.
      • NOTICE: If the memory module/modem cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
      Ask FixBot
Finish Line
Author
with
Terrence15
80,173 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 49
All Time: 738
