Dell Inspiron 15-7559 Repair Memory Modules Replacement
    1. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Back Panel: step 1, image 1 of 1
      • Turn off the computer.
      • Disconnect the charging cable from the computer.
      • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
      • Flip the computer upside down.
      Ask FixBot
    2. Dell Inspiron 15-7559 Repair Memory Modules Replacement: step 2, image 1 of 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: step 2, image 2 of 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: step 2, image 3 of 3
      • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
      • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
      Ask FixBot
    3. Dell Inspiron 15-7559 Repair Memory Modules Replacement: step 3, image 1 of 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: step 3, image 2 of 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: step 3, image 3 of 3
      • Use the blue, plastic opening tool to gently pry a section of the back panel open.
      • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
      • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
      Ask FixBot
    1. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Popping up the Memory Module: step 4, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
      Ask FixBot
    2. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Sliding the Memory Module: step 5, image 1 of 1
      • Slide and remove the memory module from the memory-module slot.
      Ask FixBot
    3. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Align the Notch: step 6, image 1 of 1
      • Align the notch on the NEW memory module with the tab on the memory-module slot.
      Ask FixBot
    4. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Sliding the Memory Module: step 7, image 1 of 1
      • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
      • NOTE: If you do not hear the click, remove the memory module and reinstall it.
      Ask FixBot
Finish Line
2 other people completed this guide.
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 68
All Time: 1,694
