Up to 20% off select tools
Dell Inspiron 15-7548 RAM Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
55
All Time:
942
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your Dell Inspiron 15-7548 laptop is struggling to process the amount of apps you typically use, upgrading your RAM sticks may be a good option to keep the laptop working smoothly.
Before upgrading your RAM sticks, make sure all your laptop software is up to date. This could be another reason your computer is not operating at peak efficiency.
Before beginning, make sure to power off your laptop completely, and disconnect the laptop from any external power source.
    1. Dell Inspiron 15-7548 RAM Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 15-7548 RAM Replacement, Back Panel: step 1, image 2 of 2
      • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
      • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
      • The four screws on the bottom are captive screws and cannot be removed.
      Ask FixBot
    2. Dell Inspiron 15-7548 RAM Replacement: step 2, image 1 of 2 Dell Inspiron 15-7548 RAM Replacement: step 2, image 2 of 2
      • Input the flat end of the spudger into the seam that is in between the back panel and the upper case, then slide it along the edge to release the plastic chips.
      • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
      Ask FixBot
    1. Dell Inspiron 15-7548 RAM Replacement, RAM: step 3, image 1 of 1
      • Pull the clips away from the side of the RAM stick.
      Ask FixBot
    2. Dell Inspiron 15-7548 RAM Replacement: step 4, image 1 of 2 Dell Inspiron 15-7548 RAM Replacement: step 4, image 2 of 2
      • Lift the RAM up and away from the motherboard.
      Ask FixBot
    3. Dell Inspiron 15-7548 RAM Replacement: step 5, image 1 of 1
      • If there is a second RAM stick, pull the clips away from the side of the RAM stick.
      Ask FixBot
    4. Dell Inspiron 15-7548 RAM Replacement: step 6, image 1 of 2 Dell Inspiron 15-7548 RAM Replacement: step 6, image 2 of 2
      • Lift the RAM stick up and away from the motherboard.
      Ask FixBot
Author
with
Michael Nunez
367 Reputation
2 Guides authored
IUPUI, Team 3-3, Beck Spring 2022 Member of IUPUI, Team 3-3, Beck Spring 2022
IUPUI-BECK-S22S3G3
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 55
All Time: 942
