Dell Inspiron 15-7548 Power Port Replacement
    1. Dell Inspiron 15-7548  Power Port Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 15-7548  Power Port Replacement, Back Panel: step 1, image 2 of 2
      • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
      • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
      • The four screws on the bottom are captive screws and cannot be removed.
      Ask FixBot
    2. Dell Inspiron 15-7548  Power Port Replacement: step 2, image 1 of 2 Dell Inspiron 15-7548  Power Port Replacement: step 2, image 2 of 2
      • Pry out the back panel using the flat head side of the spudger.
      • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
      Ask FixBot
    1. Dell Inspiron 15-7548  Power Port Replacement, Power Port: step 3, image 1 of 2 Dell Inspiron 15-7548  Power Port Replacement, Power Port: step 3, image 2 of 2
      • Grab the wires and lightly pull to remove the power port from the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 56
All Time: 818
