Dell Inspiron 15-7548 Battery Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
87
All Time:
3,308
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 9 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing a dead or damaged battery in your Dell Inspiron 15-7548.
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
    1. Dell Inspiron 15-7548  Battery Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 15-7548  Battery Replacement, Back Panel: step 1, image 2 of 2
      • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
      • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
      • The four screws on the bottom are captive screws and cannot be removed.
      Ask FixBot
    2. Dell Inspiron 15-7548  Battery Replacement: step 2, image 1 of 2 Dell Inspiron 15-7548  Battery Replacement: step 2, image 2 of 2
      • Pry out the back panel using the flat head side of the spudger.
      • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
      Ask FixBot
    1. Dell Inspiron 15-7548  Battery Replacement, Battery: step 3, image 1 of 2 Dell Inspiron 15-7548  Battery Replacement, Battery: step 3, image 2 of 2
      • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
      Ask FixBot
    2. Dell Inspiron 15-7548  Battery Replacement: step 4, image 1 of 2 Dell Inspiron 15-7548  Battery Replacement: step 4, image 2 of 2
      • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
      Ask FixBot
4 other people completed this guide.
1 Guide Comment
Little grey piece on the cable popped off, will that affect anything? Laptop isn’t recognizing that it has a battery after I took it out and put it back in.
Taylor - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 87
All Time: 3,308
