Dell Inspiron 15-7547 LCD Assembly Replacement
    1. Dell Inspiron 15-7547 LCD Assembly Replacement, Bottom Cover: step 1, image 1 of 1
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Close the display and flip the laptop on its back.
      • Loosen the ten 5.0 mm-long Phillips #0 screws.
      • The four screws marked with orange will remain captive to the cover.
      Ask FixBot
    2. Dell Inspiron 15-7547 LCD Assembly Replacement: step 2, image 1 of 1
      • Use a spudger to pry up and loosen the back cover.
      • Remove the back cover.
      Ask FixBot
    1. Dell Inspiron 15-7547 LCD Assembly Replacement, WiFi Card: step 3, image 1 of 2 Dell Inspiron 15-7547 LCD Assembly Replacement, WiFi Card: step 3, image 2 of 2
      • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
      Ask FixBot
    2. Dell Inspiron 15-7547 LCD Assembly Replacement: step 4, image 1 of 2 Dell Inspiron 15-7547 LCD Assembly Replacement: step 4, image 2 of 2
      • Remove the Wifi-Card from its socket by pulling away and up from the connector.
      Ask FixBot
    3. Dell Inspiron 15-7547 LCD Assembly Replacement: step 5, image 1 of 2 Dell Inspiron 15-7547 LCD Assembly Replacement: step 5, image 2 of 2
      • Disconnect the white and black cables from the Wifi-Card.
      • Make a note of which wire goes where for reconnecting them to the replacement card.
      Ask FixBot
    1. Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: step 6, image 1 of 3 Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: step 6, image 2 of 3 Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: step 6, image 3 of 3
      • Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
      Ask FixBot
    2. Dell Inspiron 15-7547 LCD Assembly Replacement: step 7, image 1 of 3 Dell Inspiron 15-7547 LCD Assembly Replacement: step 7, image 2 of 3 Dell Inspiron 15-7547 LCD Assembly Replacement: step 7, image 3 of 3
      • Use a spudger to unlatch and unplug the display cable.
      • There will be a notch on the side of the connector.
      Ask FixBot
    3. Dell Inspiron 15-7547 LCD Assembly Replacement: step 8, image 1 of 3 Dell Inspiron 15-7547 LCD Assembly Replacement: step 8, image 2 of 3 Dell Inspiron 15-7547 LCD Assembly Replacement: step 8, image 3 of 3
      • Raise the left and right hinges.
      Ask FixBot
    4. Dell Inspiron 15-7547 LCD Assembly Replacement: step 9, image 1 of 1
      • Remove the LCD display assembly from the laptop.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 30
All Time: 1,071
