Dell Inspiron 15-7537 Wireless Card Replacement
    1. Dell Inspiron 15-7537 Wireless Card Replacement, Bottom Case: step 1, image 1 of 1
      • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
      • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
      • These screws will stay captive to the case.
      Ask FixBot
    2. Dell Inspiron 15-7537 Wireless Card Replacement: step 2, image 1 of 1
      • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
      Ask FixBot
    3. Dell Inspiron 15-7537 Wireless Card Replacement: step 3, image 1 of 1
      • Use a spudger to remove the base cover from the rest of bottom cover.
      Ask FixBot
    1. Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: step 4, image 1 of 2 Dell Inspiron 15-7537 Wireless Card Replacement, Remove the WiFi Card: step 4, image 2 of 2
      • Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
      Ask FixBot
    2. Dell Inspiron 15-7537 Wireless Card Replacement: step 5, image 1 of 1
      • Disconnect the two antennas (one black and one white) from the wireless card.
      Ask FixBot
    3. Dell Inspiron 15-7537 Wireless Card Replacement: step 6, image 1 of 1
      • Remove the WiFi card.
      • To place a new WiFi card, connect the antenna cables to the WiFi card. The white cable goes to the white triangle, and the black cable goes to the black triangle.
      • Avoid damaging the card by not placing any cables underneath the card.
      Ask FixBot
Finish Line
Jean Whitmore
984 Reputation
7 Guides authored
Cal Poly, Team 18-2, Maness Winter 2015 Member of Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 37
All Time: 4,150
