Dell Inspiron 15-7537 RAM Replacement
    1. Dell Inspiron 15-7537 RAM Replacement, Bottom Case: step 1, image 1 of 1
      • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
      • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
      • These screws will stay captive to the case.
      Ask FixBot
    2. Dell Inspiron 15-7537 RAM Replacement: step 2, image 1 of 1
      • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
      Ask FixBot
    3. Dell Inspiron 15-7537 RAM Replacement: step 3, image 1 of 1
      • Use a spudger to remove the base cover from the rest of bottom cover.
      Ask FixBot
    1. Dell Inspiron 15-7537 RAM Replacement, RAM: step 4, image 1 of 2 Dell Inspiron 15-7537 RAM Replacement, RAM: step 4, image 2 of 2
      • Gently pull apart clips on the ends of the memory module until the memory module pops up.
      Ask FixBot
    2. Dell Inspiron 15-7537 RAM Replacement: step 5, image 1 of 1
      • Pull the RAM out at a 45 degree angle.
      Ask FixBot
2 other people completed this guide.
Jean Whitmore
984 Reputation
7 Guides authored
Cal Poly, Team 18-2, Maness Winter 2015 Member of Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 111
All Time: 2,984
