Dell Inspiron 15-7537 Battery Replacement
    1. Dell Inspiron 15-7537 Battery Replacement, Bottom Case: step 1, image 1 of 1
      • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
      • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
      • These screws will stay captive to the case.
      Ask FixBot
    2. Dell Inspiron 15-7537 Battery Replacement: step 2, image 1 of 1
      • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
      Ask FixBot
    3. Dell Inspiron 15-7537 Battery Replacement: step 3, image 1 of 1
      • Use a spudger to remove the base cover from the rest of bottom cover.
      Ask FixBot
    1. Dell Inspiron 15-7537 Battery Replacement, Battery: step 4, image 1 of 1
      • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
      Ask FixBot
    2. Dell Inspiron 15-7537 Battery Replacement: step 5, image 1 of 1
      • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
      • Using the pull tab on the battery, lift the battery out of the computer.
      Ask FixBot
4 other people completed this guide.
Abby Schmiedt
229 Reputation
1 Guide authored
Cal Poly, Team 18-2, Maness Winter 2015 Member of Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 46
All Time: 7,773
