Dell Inspiron 15-5567 Wireless Card Replacement
    1. Dell Inspiron 15-5567 Wireless Card Replacement, Back Cover: step 1, image 1 of 3 Dell Inspiron 15-5567 Wireless Card Replacement, Back Cover: step 1, image 2 of 3 Dell Inspiron 15-5567 Wireless Card Replacement, Back Cover: step 1, image 3 of 3
      • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
      • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
      • Remove two M2x4mm screws using the same screwdriver.
      Ask FixBot
    2. Dell Inspiron 15-5567 Wireless Card Replacement: step 2, image 1 of 2 Dell Inspiron 15-5567 Wireless Card Replacement: step 2, image 2 of 2
      • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
      • Slide the rest of it out with your hand.
      Ask FixBot
    3. Dell Inspiron 15-5567 Wireless Card Replacement: step 3, image 1 of 3 Dell Inspiron 15-5567 Wireless Card Replacement: step 3, image 2 of 3 Dell Inspiron 15-5567 Wireless Card Replacement: step 3, image 3 of 3
      • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
      • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
      • Grab the corners of the cover firmly and lift it up.
      • Some parts are weaker than others; open it gently from corners.
      Ask FixBot
    1. Dell Inspiron 15-5567 Wireless Card Replacement, Wireless Card: step 4, image 1 of 3 Dell Inspiron 15-5567 Wireless Card Replacement, Wireless Card: step 4, image 2 of 3 Dell Inspiron 15-5567 Wireless Card Replacement, Wireless Card: step 4, image 3 of 3
      • Remove one M2x3mm screw from the bracket holding the card using a Phillips #0 screwdriver.
      • Lift and remove the bracket with your hand.
      Ask FixBot
    2. Dell Inspiron 15-5567 Wireless Card Replacement: step 5, image 1 of 3 Dell Inspiron 15-5567 Wireless Card Replacement: step 5, image 2 of 3 Dell Inspiron 15-5567 Wireless Card Replacement: step 5, image 3 of 3
      • Disconnect the antennae cables connected to the card using the opening tool.
      • Slide the wireless card off of its socket and lift it with your hand and remove it.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 34
All Time: 1,862
