Dell Inspiron 15-5565 RAM Replacement
    1. Dell Inspiron 15-5565 RAM Replacement, Optical Drive: step 1, image 1 of 1
      • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
      Ask FixBot
    2. Dell Inspiron 15-5565 RAM Replacement: step 2, image 1 of 3 Dell Inspiron 15-5565 RAM Replacement: step 2, image 2 of 3 Dell Inspiron 15-5565 RAM Replacement: step 2, image 3 of 3
      • Eject the optical drive by pressing the eject button.
      • Push out the optical drive bracket using the iFixit opening tool.
      Ask FixBot
    1. Dell Inspiron 15-5565 RAM Replacement, Back Cover: step 3, image 1 of 2 Dell Inspiron 15-5565 RAM Replacement, Back Cover: step 3, image 2 of 2
      • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
      • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
      • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
      Ask FixBot
    2. Dell Inspiron 15-5565 RAM Replacement: step 4, image 1 of 2 Dell Inspiron 15-5565 RAM Replacement: step 4, image 2 of 2
      • Remove the back cover from the laptop.
      Ask FixBot
    1. Dell Inspiron 15-5565 RAM Replacement, RAM: step 5, image 1 of 3 Dell Inspiron 15-5565 RAM Replacement, RAM: step 5, image 2 of 3 Dell Inspiron 15-5565 RAM Replacement, RAM: step 5, image 3 of 3
      • Use your fingers to pull the safety clips apart on either side of the memory module. This should make the module pop upwards.
      • Remove the module from its slot by pulling it out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 62
All Time: 630
