Dell Inspiron 15-5559 Back Panel Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
Past 7 Days:
30
Past 30 Days:
101
All Time:
3,290
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Before removing the back panel, make sure the device is disconnected from any power source. Make sure that your battery has also been removed.
Parts
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Dell Inspiron 15-5559 Back Panel Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 15-5559 Back Panel Replacement, Back Panel: step 1, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
      Ask FixBot
    2. Dell Inspiron 15-5559 Back Panel Replacement: step 2, image 1 of 2 Dell Inspiron 15-5559 Back Panel Replacement: step 2, image 2 of 2
      • Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
      • Do not be afraid to use a bit of muscle, as the panel does not come off without some force.
      Ask FixBot
2 other people completed this guide.
Kyla Ward
649 Reputation
4 Guides authored
Baylor, Team S5-G5, Williams Spring 2018 Member of Baylor, Team S5-G5, Williams Spring 2018
BU-WILLIAMS-S18S5G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 101
All Time: 3,290
