Dell Inspiron 15-5558 RAM Replacement
    1. Dell Inspiron 15-5558 RAM Replacement, Battery: step 1, image 1 of 1
      • Make sure you turn off the device before starting.
      • Flip the device over and so the white bar code is on the right.
      Ask FixBot
    2. Dell Inspiron 15-5558 RAM Replacement: step 2, image 1 of 1
      • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
      Ask FixBot
    3. Dell Inspiron 15-5558 RAM Replacement: step 3, image 1 of 2 Dell Inspiron 15-5558 RAM Replacement: step 3, image 2 of 2
      • Rotate the battery up and remove it.
      Ask FixBot
    1. Dell Inspiron 15-5558 RAM Replacement, Hard Drive: step 4, image 1 of 3 Dell Inspiron 15-5558 RAM Replacement, Hard Drive: step 4, image 2 of 3 Dell Inspiron 15-5558 RAM Replacement, Hard Drive: step 4, image 3 of 3
      • Using a Phillips #0 screwdriver, unscrew the two 8mm screws from the panel.
      • Take a spudger and wedge it between the panel and the base of the device.
      • Push down on the spudger until you hear a click sound.
      • Slide the spudger along the panel and continue to push down until the panel is completely detached.
      • Remove the panel.
      Ask FixBot
    2. Dell Inspiron 15-5558 RAM Replacement: step 5, image 1 of 3 Dell Inspiron 15-5558 RAM Replacement: step 5, image 2 of 3 Dell Inspiron 15-5558 RAM Replacement: step 5, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the four 8mm screws holding down the hard drive.
      • Take the spudger and prop up the connector so it is no longer attached.
      • Use the spudger and prop up the hard drive and remove it.
      Ask FixBot
    1. Dell Inspiron 15-5558 RAM Replacement, RAM: step 6, image 1 of 3 Dell Inspiron 15-5558 RAM Replacement, RAM: step 6, image 2 of 3 Dell Inspiron 15-5558 RAM Replacement, RAM: step 6, image 3 of 3
      • Locate the two RAM cards.
      • Using your finger, pull the two small pins back from the RAM causing it to pop up.
      Ask FixBot
    2. Dell Inspiron 15-5558 RAM Replacement: step 7, image 1 of 1
      • Once popped up, pull the ram out.
      Ask FixBot
Adam Lourenco
844 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 107
All Time: 2,130
