Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓The following guide will give instructions on how to properly replace the RAM/Memory on your Dell Inspiron 15-5552.
Tools
Use a J0 screwdriver to unscrew the two, 6mm Phillips screw on the rear-cover.
Using a spudger, Lightly lift the rear-cover up and at an angle, away from the computer.
Use your fingers to carefully pull the securing clips on the RAM away from each other.
Remove the dislodged up RAM by pulling it away from the connection.
