Dell Inspiron 15-5552 CD-Drive Replacement
    1. Dell Inspiron 15-5552 CD-Drive Replacement, Battery: step 1, image 1 of 1
      • Make sure the laptop is powered down before you remove the battery.
      Ask FixBot
    2. Dell Inspiron 15-5552 CD-Drive Replacement: step 2, image 1 of 1
      • Locate the battery release switch on the bottom of the laptop.
      Ask FixBot
    3. Dell Inspiron 15-5552 CD-Drive Replacement: step 3, image 1 of 1
      • Slide the battery release switch away from the lock symbol towards the “unlock” position.
      • You can tell that the battery is unlocked once you hear a "click."
      Ask FixBot
    4. Dell Inspiron 15-5552 CD-Drive Replacement: step 4, image 1 of 2 Dell Inspiron 15-5552 CD-Drive Replacement: step 4, image 2 of 2
      • Rotate the battery outward by lifting the bottom lip that pops out.
      • Continue rotating the battery towards the top of the laptop until the battery is completely removed.
      Ask FixBot
    1. Dell Inspiron 15-5552 CD-Drive Replacement, Keyboard: step 5, image 1 of 2 Dell Inspiron 15-5552 CD-Drive Replacement, Keyboard: step 5, image 2 of 2
      • Keyboard
      • Insert a spudger next to the 5 plastic indents located at the top of the keyboard and gently pry to release the securing clips.
      Ask FixBot
    2. Dell Inspiron 15-5552 CD-Drive Replacement: step 6, image 1 of 2 Dell Inspiron 15-5552 CD-Drive Replacement: step 6, image 2 of 2
      • Lift the keyboard off of the computer. *Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.*
      Ask FixBot
    3. Dell Inspiron 15-5552 CD-Drive Replacement: step 7, image 1 of 1
      • Flip the keyboard over onto the palm-rest assembly.
      Ask FixBot
    4. Dell Inspiron 15-5552 CD-Drive Replacement: step 8, image 1 of 2 Dell Inspiron 15-5552 CD-Drive Replacement: step 8, image 2 of 2
      • Flip the black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
      Ask FixBot
    1. Dell Inspiron 15-5552 CD-Drive Replacement, CD-Drive: step 9, image 1 of 1
      • CD-Drive
      • Flip the computer over, *screen down* and unscrew the 1 screw in the middle located below the battery with a J0 bit tipped screwdriver.
      Ask FixBot
    2. Dell Inspiron 15-5552 CD-Drive Replacement: step 10, image 1 of 1
      • Next using the J0 bit tipped screwdriver unscrew the 2 remaining screws shown in the picture.
      Ask FixBot
    3. Dell Inspiron 15-5552 CD-Drive Replacement: step 11, image 1 of 2 Dell Inspiron 15-5552 CD-Drive Replacement: step 11, image 2 of 2
      • After all 3 screws are removed take a spudger and pry the CD-Drive out of the computer.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 35
All Time: 533
