Dell Inspiron 15-5548 Wi-Fi Chip Replacement
    1. Dell Inspiron 15-5548 Wi-Fi  Chip Replacement, Wi-Fi  Chip: step 1, image 1 of 3 Dell Inspiron 15-5548 Wi-Fi  Chip Replacement, Wi-Fi  Chip: step 1, image 2 of 3 Dell Inspiron 15-5548 Wi-Fi  Chip Replacement, Wi-Fi  Chip: step 1, image 3 of 3
      • Make sure the computer is unplugged and turned off before you start this procedure.
      • Use a Phillips #00 screwdriver to unscrew both bottom cover screws, and remove the bottom cover.
      • The bottom cover can be hard to pull off, so you may need to pry it off with a pry tool.
      Ask FixBot
    2. Dell Inspiron 15-5548 Wi-Fi  Chip Replacement: step 2, image 1 of 2 Dell Inspiron 15-5548 Wi-Fi  Chip Replacement: step 2, image 2 of 2
      • Locate the Wi-Fi chip in the upper left corner of the laptop.
      • Remove the screw at the top of the chip.
      Ask FixBot
    3. Dell Inspiron 15-5548 Wi-Fi  Chip Replacement: step 3, image 1 of 2 Dell Inspiron 15-5548 Wi-Fi  Chip Replacement: step 3, image 2 of 2
      • The chip should pop up once the screw is gone.
      • Now remove the chip and insert the new one.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When inserting new chip make sure it pops up when not secured by the screw.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 118
All Time: 1,528
