Dell Inspiron 15-5547 Keyboard Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
81
All Time:
1,507
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide is for removing or replacing a keyboard for the Dell Inspiron 15-5547. This action may need to be taken in order to remove and replace a non-functioning keyboard. You may also need a replacement keyboard component specific to the Dell Inspiron 15-5547 if you intend to replace a defective keyboard. Be careful not to pull the keyboard too quickly or harshly throughout the removal steps in order avoid damaging the connector ribbon cables of the keyboard.
Parts
Tools
    1. Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: step 1, image 1 of 3 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: step 1, image 2 of 3 Dell Inspiron 15-5547 Keyboard Replacement, Keyboard: step 1, image 3 of 3
      • Use the Jimmy to pry and detach the keyboard from the laptop at the following locations.
      • Lift the keyboard from the top and gently detach it from the bottom end.
      • Be careful not to pull too quickly in order to avoid damage to the keyboard connector ribbon cables.
      Ask FixBot
    2. Dell Inspiron 15-5547 Keyboard Replacement: step 2, image 1 of 2 Dell Inspiron 15-5547 Keyboard Replacement: step 2, image 2 of 2
      • Detach the smaller ribbon cable from the laptop connector base by gently pulling upward on the connector base. This will free the ribbon cable.
      • Detach the larger ribbon cable from the laptop connector base in the same manner as the first. This will completely detach the keyboard from the laptop.
      • Be careful when detaching and removing the ribbon cables so as not to tear or damage them.
      Ask FixBot
4 other people completed this guide.
Faiq Huzir
121 Reputation
1 Guide authored
IUPUI, Team S1-G3, Harley Summer 2019 Member of IUPUI, Team S1-G3, Harley Summer 2019
IUPUI-HARLEY-SU19S1G3
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 81
All Time: 1,507
